Author Topic: Brief Mode Insert Leaves inserted test highlighted  (Read 2221 times)
mkatz
« on: October 19, 2015, 04:10:37 pm »
I'm not sure if this is a bug or a difference in configuration between v19 and v20.  Possibly default configuration.
In Brief mode do the following:
  • Highlight some text (ALT-L and cursor up or down will do this)
  • Copy the text to the clipboard (Numeric Keypad Plus will do this)
  • Go to the end of the document (END-END-END will do this)
  • Insert the copied text (The insert key will do this)
The inserted text will be highlighted.
  • Hero Points: 499
Re: Brief Mode Insert Leaves inserted test highlighted
« Reply #1 on: October 19, 2015, 06:26:27 pm »
Didn't happen for me.  Make sure the macro variable "def_deselect_paste" is set to 1 (Macro>Set Macro Variable...).
mkatz
« Reply #2 on: October 20, 2015, 01:47:42 pm »
Clark,
That fixed it.  Thanks.
             Mike
