Author Topic: RC1: Freeze on beautify  (Read 2420 times)
warnerrs
  • Hero Points: 4
« on: October 22, 2015, 06:40:46 pm »
Linux
Clean ~/.slickedit (deleted)
SystemVerilog
Beautify
Freeze
Video:
https://youtu.be/7NSntQS7VqU
Sorry for the low quality YouTube video, attach doesn't seem to be working.
  • Hero Points: 141
Re: RC1: Freeze on beautify
« Reply #1 on: October 22, 2015, 08:02:26 pm »
Odd, the section of the code I saw on screen doesn't seem to cause problems by it self, though I may have mangled it trying to read it on the video.
  If you can't send the problem file, can you comment out bits of the file to narrow down what piece of syntax we're getting stuck on?
warnerrs
  • Hero Points: 4
« Reply #2 on: October 22, 2015, 10:05:27 pm »
This is all I need to reproduce the hang.
`timescale 1ns/1ps
// tb
//  MODULE: tb_top
module tb_top();
    initial uvm_config_db#(virtual rif)::set( null, "uvm_test_top.env.rif_agent", "vif", r_if );
endmodule
  • Hero Points: 141
« Reply #3 on: October 23, 2015, 01:11:48 pm »
Hmm, I can reproduce it with that.  Looking into it, thanks for narrowing it down.
  • Hero Points: 141
« Reply #4 on: October 23, 2015, 01:37:39 pm »
Fixed for the next build.
