Author Topic: SE2015 "Modify Variable" dialog not raised when debugging perl  (Read 1912 times)
tuchman
  • Hero Points: 7
« on: October 23, 2015, 06:25:48 am »
Simple perl project
Step into code
In locals window, double-click on a variable's "value" column
In SE2014, a "Modify Variable" dialog was raised.
In SE2015, can't find any way to change a variable's value
SlickEdit Pro 2015 (v20.0.0.7 64-bit)
Build Date: October 20, 2015
Emulation: CUA
OS: Windows 7 x64
Memory: 41% Load, 3348MB/8055MB Physical, 3927MB/16109MB Page File, 325MB/8388607MB Virtual
Shell Information: C:\windows\system32\cmd.exe /q
Screen Size: 1280 x 1024, 1920 x 1080
Project Type: Cpp
Language: .c (C/C++)
Encoding: Automatic
Installation Directory: C:\bin\se2015\ (non-removable drive,NTFS,37117MB free)
Configuration Directory: d:\data\se2013\20.0.0\ (non-removable drive,NTFS,5015MB free)
Migrated from: d:\data\se2013\19.0.2\
Sandra
  • Hero Points: 36
Re: SE2015 "Modify Variable" dialog not raised when debugging perl
« Reply #1 on: October 23, 2015, 03:37:26 pm »
I'm looking into this.
Sandra
  • Hero Points: 36
« Reply #2 on: October 26, 2015, 02:13:39 pm »
This is fixed for the next drop.  Thanks for the bug report!
