Author Topic: Python beautifier adds space at end of every triple quoted comment line  (Read 2963 times)
elekven
Like the subject says, run the Python beautifier with standard config, and every line within a triple quoted comment gets a space appended.
  • Hero Points: 140
Re: Python beautifier adds space at end of every triple quoted comment line
« Reply #1 on: October 26, 2015, 08:52:59 pm »
Strangely, I can't get this to happen in little test files I've thrown together.  Can you post a small example that does it?
elekven
« Reply #2 on: October 26, 2015, 11:46:44 pm »
Try this very short file with my python options.
  • Hero Points: 140
« Reply #3 on: October 27, 2015, 01:32:41 pm »
I can reproduce it with that file - it has to do with the line endings, so it won't happen with the default LF line ending on my linux box.  Working on it, thanks for the report.
  • Hero Points: 140
« Reply #4 on: October 27, 2015, 02:21:16 pm »
Fixed for the next build.
