Author Topic: File Path Popup Choices Don't Appear To Work In 2015 Beta  (Read 2438 times)
rascheri
« on: October 27, 2015, 05:15:00 pm »
While trying to compare two files, the DiffZilla dialog appears and I start entering the file path to the first file I want to compare. In Version 2014 Pro as I type letters, SlickEdit would popup the choices available within the given path, if the path was correct.  In Version 2015 Pro Beta this does not appear to be working. No choices popup while I'm typing. Perhaps this is a feature that was disabled?
  • Hero Points: 141
Re: File Path Popup Choices Don't Appear To Work In 2015 Beta
« Reply #1 on: October 27, 2015, 05:18:04 pm »
Reproduced.  We will look into this.  Thanks for the report.
