Author Topic: selective display button not working  (Read 2725 times)
elekven
« on: October 27, 2015, 08:58:15 pm »
Editing C source. I bring up the selective display dialog. Select "function headers". See the attached screen shot. Within the "function header comments" block, while "show" is selected, I can't usually clear the "documentation comments" box. What allows me to clear "documentation comments" is to select "other comments" or "show blank lines", then go back to clear "documentation comments".
  • Hero Points: 453
Re: selective display button not working
« Reply #1 on: October 28, 2015, 12:53:53 am »
This appears to be a limitation in the dialog. You must have either "Documentation comments" or "Other comments" checked. However, you can have both checked. That's why these aren't radio buttons.
  • Hero Points: 453
« Reply #2 on: October 28, 2015, 05:40:18 pm »
Would this make more sense if there were two sets of radio buttons for documentation comments and other comments?
Documentation comments   (o) Show   O Collapse    O  Hide
Other comments                  O  Show   O Collapse   (o) Hide
[ ] Show blank lines
  • Hero Points: 289
« Reply #3 on: October 29, 2015, 08:11:41 am »
Good idea Dennis ! That would allow better, fine grained control.
