Author Topic: RC3 SystemVerilog macro beautification  (Read 6412 times)
warnerrs
  • Hero Points: 4
« on: October 29, 2015, 10:11:50 pm »
Very common in SystemVerilog is defining classes in macros like this:
    `define rvm_export_suffix( SUFFIX )                                               \
    class rvm_export``SUFFIX#( type TARGET=rvm_export_base ) extends rvm_export_base; \
        function new(string name = "", rvm_component parent = null);                  \
            super.new(name,parent);                                                   \
        endfunction        \
        virtual function void write( rvm_object obj );                                \
            TARGET tgt;                                                               \
            $cast(tgt, m_parent);                                                     \
            tgt.write``SUFFIX( obj );                                                 \
        endfunction        \
    endclass
After beautification, it looks like this:
    endfunction        \
    TARGET tgt;                                                               \
    endfunction        \
    endclass
  • Hero Points: 142
Re: RC3 SystemVerilog macro beautification
« Reply #1 on: October 30, 2015, 01:59:26 pm »
Reproduced, I'll take a look at it.
  • Hero Points: 142
« Reply #2 on: November 04, 2015, 02:42:09 pm »
Fixed in rc5.
