Author Topic: RC-4 SystemVerilog beautifier 'align variables' inconsistent  (Read 9721 times)
tim_k
  • Hero Points: 12
  • -Tim
« on: October 30, 2015, 09:02:04 PM »
With the 'Align variables' option set in the beautifier format dialog, this is not fixed:
  logic [31:0]                          roiFrameBuffer0StartAddr;
  logic [31:0]                       roiFrameBuffer1StartAddr;
  logic [31:0]                          roiFrameBuffer2StartAddr;
  logic   [31:0]                         roiFrameBuffer3StartAddr;
  logic [31:0]                          roiStartOffset;
It should look like this:
Or in isolation like this (this is part of a much larger list, with longer 'logic [...]' statements), the variables a space or tab off of the ']'.
-Tim
  • Hero Points: 151
Re: RC-4 SystemVerilog beautifier 'align variables' inconsistent
« Reply #1 on: November 02, 2015, 03:46:19 PM »
I've found a few contexts where the variables aren't being aligned.  (like in a typedef'd struct).  Just to make sure I'm not missing anything, where were you seeing these?
tim_k
  • Hero Points: 12
  • -Tim
« Reply #2 on: November 04, 2015, 05:42:44 AM »
These are just in a signals list at the beginning of the module...
module #(...)(....);
parameters ....
logic [...] signal;
many more then the rest of the logic, etc.
-Tim
  • Hero Points: 151
« Reply #3 on: November 10, 2015, 05:08:59 PM »
As an update, I suspect this is a parser bug.   I've been adding more files to the regression tests, and have flushed out a couple of parse errors that can cause the signals list to not be aligned.
So I'll clean these up and see if I find any others;  once it gets closer to point release time, I can send you some files and we can see if it's fixed with your source code.
tim_k
  • Hero Points: 12
  • -Tim
« Reply #4 on: November 10, 2015, 09:31:53 PM »
Sounds good. Anytime you want to test SystemVerilog, Verilog, or VHDL type things with a user, let me know.
-Tim.
