Author Topic: Copy WYSIWYG  (Read 672 times)
  • Hero Points: 184
Copy WYSIWYG
« on: November 07, 2015, 07:11:58 pm »
it would be nice if there was a WYSIWYG copy ...
So if you are in Hex or LineHex or special character mode or with linenumbers, when you copy a selection it would copy such that when you paste into notepad it would look the same as it does in Slickedit.
import java.awt.Event;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
Should be this when line-numbers are enabled
1:  import java.awt.Event;
2:  import java.awt.event.ActionEvent;
3:  import java.awt.event.ActionListener;
And in line numbers + line-hex + special characters mode, it should be
1:  import java.awt.Event;¶
    667677266762677247667300
    9D0F240A161E174E565E4BDA
2:  import java.awt.event.ActionEvent;¶
    667677266762677267667246766647667300
    9D0F240A161E174E565E4E1349FE565E4BDA
3:  import java.awt.event.ActionListener;¶
    667677266762677267667246766646776667300
    9D0F240A161E174E565E4E1349FEC9345E52BDA
