Author Topic: Block Comment / Uncomment macro  (Read 29595 times)
aoehlke
Re: Block Comment / Uncomment macro
« Reply #15 on: August 28, 2006, 07:08:48 PM »
very cool... it works well. karma to you.
now the global env thing sounds intruiging... since I just sent out an email to 10 developers on how to add this to their set of commands (ie import the macro) as well as how to add it to the select menu.
Granted, people will always want their own customizations as well.  Is it possible to have a global env file, and then have per user settings override anything that may be specified in both?  and if the block comment macro can be imported into the global file, can the changes to the select menu also propogate to all users?
maybe I am asking for too much :)
  • Hero Points: 292
« Reply #16 on: August 28, 2006, 07:51:18 PM »
The menus are also Slick-C code - really cool ... (have look into config\vusrs11f.e -> Slickv11)
However, I'd propose to share such things per source.
Maybe one writes a macro which (re-)loads e.g. all '*.e' files from a server share.
There are more possibilties but it's not that easy to avoid messing up things ...
And if a Slick update kicks in it's anyway better to check your macros if they are still working (mosty they do).
ewjax
« Reply #17 on: September 10, 2006, 06:32:23 PM »
HS2, nice changes, thanks!
