Author Topic: mark modified lines  (Read 1459 times)
dbbd
mark modified lines
« on: December 10, 2015, 09:12:59 am »
I'm looking for the feature that puts marks on modified lines in the left side of the editor window.
Cannot figure out how its called and how to find it in the options.
  • Hero Points: 55
Re: mark modified lines
« Reply #1 on: December 10, 2015, 02:48:47 pm »
That setting will be under the View page of your language settings.  So if you have a C++ file open, and you go to Document -> C/C++ Options -> View the option will be a checkbox on the right hand side: "Modified lines".
dbbd
« Reply #2 on: December 10, 2015, 03:30:29 pm »
Thank you!
