Author Topic: file filters help  (Read 2883 times)
dbbd
file filters help
« on: December 15, 2015, 02:42:17 pm »
In the open file pane I get the list of files that match the prefix I type.
This list includes files ending with .contrib (created by clearcase).
I cannot figure out where and how to define the file filter that will stop showing me these files.
Any help would be appreciated.
dbbd
Re: file filters help
« Reply #1 on: December 21, 2015, 10:46:00 am »
Anyone?
mjdl
  • Hero Points: 14
  • SE 23 + hotfix 1 x64 Windows 10 1809
« Reply #2 on: February 24, 2016, 07:25:31 pm »
I don't think there's a setting or configuration variable that allows global exclusion of a particular file type from file lists--presumably it's possible to make a custom version of the file listing function(s) to do this.
The only work-around I can see is to use Options-->File Options-->Files of Type Filters, specify your own global File Type list type that includes all the types you need, and place it first on the list.
  • Hero Points: 357
« Reply #3 on: February 29, 2016, 10:25:37 pm »
There isn't an exclude file spec yet. Good idea though.
