Author Topic: "Replaced # occurrences" number incorrect  (Read 1354 times)
pmsteinm
  • Hero Points: 3
« on: March 28, 2016, 04:58:39 pm »
Starting with hf7 I've noticed that the replaced occurrences count indicates 1 higher than actually replaced. If I do "list all occurrences" under search the count is correct. When I do replace (either replace all or stepping through) the count reads 1 higher than actual.
Slickedit Info:
OS: Linux
OS Version: SUSE Linux Enterprise Desktop 11 (x86_64)
Kernel Level: 3.0.101-0.47.55-default
Build Version: #1 SMP Thu May 28 08:25:11 UTC 2015 (dc083ee)
Hotfixes:
/usr2/psteinme/.slickedit/20.0.1/hotfixes/hotfix_se2001_2_cumulative.zip (Revision: 2)
/usr2/psteinme/.slickedit/20.0.1/hotfixes/hotfix_se2001_5_cumulative.zip (Revision: 5)
/usr2/psteinme/.slickedit/20.0.1/hotfixes/hotfix_se2001_6_cumulative.zip (Revision: 6)
/usr2/psteinme/.slickedit/20.0.1/hotfixes/hotfix_se2001_7_cumulative.zip (Revision: 7)
  • Hero Points: 432
Re: "Replaced # occurrences" number incorrect
« Reply #1 on: March 28, 2016, 10:51:50 pm »
Reproduced. We will look into this.
  • Hero Points: 432
« Reply #2 on: March 28, 2016, 11:02:47 pm »
As soon as you hit "Go" it counts one extra. Thanks for catching this.
