Author Topic: _restore_pos2 doesn't after paste  (Read 3631 times)
Mr68360
  • Hero Points: 3
« on: March 22, 2007, 10:53:34 pm »
I want to create a macro that, after pasting the clipboard (ala Ctrl-V), returns the cursor to the location of the of the cursor at the start of a paste, rather than at the end of what was pasted:
                           Normal paste leaves cursor here
                           v
|this_is_pasted_text
I want cursor here after the paste.
(BTW, if there already is a setting for this, I'll take that as well)
I tried the following:
_command paste_stay(_str name='', boolean isClipboard=true) name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
   typeless p;
   _save_pos2(p);
   int retval = paste(name, isClipboard);
   _restore_pos2(p);
   return retval;
However, the _restore_pos2() call placed the cursor at the end of the pasted text.  It's as if the position value _save_pos2() returns is modified via the paste function to the "post-paste" location.
Is there anyway to obtain the "pre-paste" location, and return the cursor to that spot?
Chuck
Mr68360
  • Hero Points: 3
Re: _restore_pos2 doesn't after paste
« Reply #1 on: March 24, 2007, 04:03:06 pm »
Figured it out!
   long ofs = _QROffset();
   _GoToROffset(ofs);
   return retval;
