Author Topic: 'Files' toolbar doesn't support different column widths ?  (Read 4898 times)
  • Hero Points: 289
« on: March 23, 2007, 12:11:16 am »
Hello SlickTeam,
it seems that the columns of the new 'Files' toolbar are auto-adjusted that the filename and pathtofile columns are equally sized. IMO that's not the best solution. I think it should save/restore each column width.
  • Hero Points: 289
Re: 'Files' toolbar doesn't support different column widths ?
« Reply #1 on: March 23, 2007, 12:30:03 pm »
Ok - it's just a small bug here:
tbfilelist.e - getColWidths() [line 562]: (the index should be 'i')
      // _TreeGetColButtonInfo(0,width,flags,state,caption);
      _TreeGetColButtonInfo(i,width,flags,state,caption);
Change - reload - have fun (for those who don't want to wait for the hotfix)
Ding Zhaojie
  • Hero Points: 37
« Reply #2 on: March 24, 2007, 03:35:00 pm »
Thanks! the column width problem bothered me, too.
  • Hero Points: 289
« Reply #3 on: May 02, 2007, 05:13:14 pm »
@SlickTeam:
The lastest hotfixes fixed tbfilelist.e but this bug is still there.
assafb
« Reply #4 on: May 16, 2007, 11:41:15 pm »
Hi,
In my enviorment I don't have access permittions to tbfilelist.e.
Tried copy tbfilelist.e to my 'hotfix' dir and do the changes there - but it doesn't seems to work.
What am I missing?
Thanks
  • Hero Points: 289
« Reply #5 on: May 17, 2007, 08:26:38 am »
Did you 'Macro->Load Module' with the hotfixed one ? Should work...
And ensure that the changed version is really newer (filedate) than tbfilelist.ex in the macro-dir.
This is normally not needed after changing it and if the time/date of your computer is setup properly ;)
« Last Edit: May 17, 2007, 08:31:43 am by hs2 »
