Author Topic: How to turn off XML comment wrapping?  (Read 2571 times)
jdmcfadden
« on: March 23, 2007, 01:52:25 pm »
I have unchecked comment wrapping in the XML file extension and restarted the application, but SlickEdit 2007 is continuing to wrap comments in XML Does anyone know a way to make this quit?
Lisa
  • Hero Points: 23
Re: How to turn off XML comment wrapping?
« Reply #1 on: March 23, 2007, 02:00:31 pm »
This is probably being done by XML/HTML Formatting (a new feature). To disable it system-wide for XML files, go to Document > XML/HTML Formatting, and uncheck "Enable XML Formatting". Or, you can just disable content wrap or tag layout for XML files individually through the same menu.
Look up "xml/html formatting" in the Help index for complete documentation and instructions for using the feature and turning it on/off.
Best wishes,
Lisa
