Author Topic: SlickEdit Core v4.3.2 for Eclipse  (Read 16411 times)
« on: July 06, 2016, 06:03:03 PM »
SlickEdit Core is a subscription plug-in for Eclipse that brings SlickEdit's rich history of excellence to the Eclipse framework. SlickEdit Core consists of the SlickEdit editor, 7 additional views, and the DIFFzilla® differencing engine.  SlickEdit Core for Eclipse is now available in both 32 and 64 bit architectures on both Windows and Linux.
To install SlickEdit Core v4.3.2 (for Eclipse 4.3 and later):
  • In Eclipse, select Help > Install New Software and click the Add button.
  • Enter the following URL for the Location: https://customer.slickedit.com/update/secore/kepler and click OK.
  • Expand the Code Editing category and mark the check box for SlickEdit Core For Eclipse.
  • Click Next and continue through the wizard to complete the install process.  You will be prompted to restart Eclipse after the installation is finished.
