Author Topic: find mini tool  (Read 3370 times)
  • Hero Points: 210
find mini tool
« on: July 15, 2016, 08:01:05 PM »
Ctrl+F
Ctrl+F  to open the full window.
Alt+Tab away from slick.
Alt+Tab back to slick
Ctrl+F - now both the mini find and full find windows are open.
Using the mouse you can switch between the two and do different searches.
  • Hero Points: 530
Re: find mini tool
« Reply #1 on: July 16, 2016, 02:09:17 AM »
This is how it's supposed to work. If you don't want to use the mini find dialog, you need to change the option (Options>Editing>Search>Default Find and Replace GUI -- set to "Tool Window").
  • Hero Points: 210
Re: find mini tool
« Reply #2 on: July 18, 2016, 06:42:10 PM »
Its not that I don't want to use minifind, it is that it seems odd to allow both like this.
Can't get focus back to mini find:Ctrl+F
Typesomething.
Click in the text editor.
Edit, or whatever.
Ctrl+F
Nothing happens - focus should move to the mini-find window.
Ctrl+F Ctrl+F -- still nothing.
Only keyboard thing to do is <esc> which closes mini-find, then Ctrl+F will open it again.
Is there a keyboard way to leave mini-find open and return focus to the edit window?
Re: find mini tool
« Reply #3 on: July 18, 2016, 06:45:14 PM »
Confirmed, there is a bug where focus isn't going back to the mini-find if it is already being displayed.  It is supposed to, so that will be fixed in next release.
