Author Topic: Installation Failure  (Read 4494 times)
b
  • Hero Points: 26
« on: July 18, 2016, 04:38:17 pm »
Tried this morning to install the new beta (Ubuntu 14.04 x86_64) and got a stack dump when it launched the license manager:
[Edit]
After trying to finish the installation, it now just gives me a fault:
bjkurlex@bullwinkle ~ $ vs -sc foo
Segmentation fault (core dumped)
« Last Edit: July 18, 2016, 04:45:42 pm by b »
Mike
  • Hero Points: 20
Re: Installation Failure
« Reply #1 on: July 18, 2016, 09:28:31 pm »
We want to get this working, and it will help if we can test it locally with your configuration files.
Please compress your configuration directory for v20.0.3, so we can try migrating it to v21 beta.
(We just need the files, not the subdirectories.)
The compression command should be something like:  tar -czf ubuntu-config.tar.gz .slickedit/20.0.3
Then please go to the following URL and enter 13509 (community topic id) for the case number -> http://support.slickedit.com
and choose the ubuntu-config.tar.gz to upload. Once it is uploaded, please reply to this message and let us know.
« Last Edit: July 18, 2016, 09:56:15 pm by Mike »
b
  • Hero Points: 26
« Reply #2 on: July 18, 2016, 09:43:19 pm »
Done.
  • Hero Points: 432
« Reply #3 on: July 18, 2016, 10:29:05 pm »
I'm not reproducing all the problems your seeing. What I am seeing is that when the license manager dialog is run by the installation program, the upgrade of your configuration isn't done correctly (end up not in VI emulation).
Here's what I did to work around the problem:
cd ~/.slickedit
rm -rf 21.0.0
Now start SlickEdit as you normally would (don't run vsinst). Even if SlickEdit prompts you for a license file, it should still upgrade your configuration correctly.
This issue should not be a problem on Windows or Mac because there is no "vsinst" program which can potentially upgrade your configuration.
We will fix this. Thanks for the post
b
  • Hero Points: 26
« Reply #4 on: July 19, 2016, 04:40:45 pm »
Following your steps, I'm still seeing some nasty slickc stack dumps.
Steps Taken:
(From a working 20.0.3 installation):
cd se_21000002_linux64_beta1
./vsinst
(/home/bjkurlex/slickedit)
Aforementioned scrambled pop ups and slickc stacks encountered.
Get to license menu and cancel.
rm -rf ~/.slickedit/21.0.0
vs &
Now I see the following windows to wade through:
(Forum has a 4 image restriction), but I'll then see that it won't switch to vim emulation, and finally registration, which I enter.
If after this I again remove the 21.0.0 configuration and do this again, it's rinse, repeat on the errors (only the garbage in the pop up error windows appear to change to protect the guilty).
After exiting and restarting, it appears not to further complain, but I'm very leary of trusting it with all the errors encountered.   (Usually I'll blow away both my ~/slickedit and ~/.slickedit directories and restore from backup).
  • Hero Points: 432
« Reply #5 on: July 19, 2016, 05:12:15 pm »
Lets thoroughly check if you can run v21 on your system.
cd to the root of the v21 install directory
Type: bin/vs +new -sc /tmp/config
b
  • Hero Points: 26
« Reply #6 on: July 19, 2016, 05:32:44 pm »
bjkurlex@bullwinkle ~/slickedit $ bin/vs +new -sc /tmp/config
bjkurlex@bullwinkle ~/slickedit $ rm -rf ~/.slickedit/21.0.0/
And just as an afterthought:
bjkurlex@bullwinkle ~/slickedit $ strace bin/vs +new -sc /tmp/config
execve("bin/vs", ["bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = 0
brk(0)                                  = 0x1f4b000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7faa40781000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib64/tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64/tls/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib64/tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64/tls", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib64/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/home/bjkurlex/lib/tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/tls/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib/tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/tls", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/home/bjkurlex/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
open("/usr/local/lib/tls/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/tls/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/x86_64", 0x7ffd94ffc620) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=92973, ...}) = 0
mmap(NULL, 92973, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7faa4076a000
close(3)                                = 0
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P \2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1840928, ...}) = 0
mmap(NULL, 3949248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7faa4019c000
mprotect(0x7faa40356000, 2097152, PROT_NONE) = 0
mmap(0x7faa40556000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1ba000) = 0x7faa40556000
mmap(0x7faa4055c000, 17088, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7faa4055c000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7faa40769000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7faa40767000
arch_prctl(ARCH_SET_FS, 0x7faa40767740) = 0
mprotect(0x7faa40556000, 16384, PROT_READ) = 0
mprotect(0x605000, 4096, PROT_READ)     = 0
mprotect(0x7faa40783000, 4096, PROT_READ) = 0
munmap(0x7faa4076a000, 92973)           = 0
brk(0)                                  = 0x1f4b000
brk(0x1f6c000)                          = 0x1f6c000
open("/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=2919792, ...}) = 0
mmap(NULL, 2919792, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7faa3fed3000
close(3)                                = 0
execve("/home/bjkurlex/bin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/usr/local/bin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/usr/local/sbin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/usr/sbin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/usr/bin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/sbin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = -1 ENOENT (No such file or directory)
execve("/bin/sh", ["sh", "bin/vs", "+new", "-sc", "/tmp/config"], [/* 49 vars */]) = 0
brk(0)                                  = 0x55aacced0000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fca080ee000
stat("/home/bjkurlex/lib64/tls/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64/tls", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib64/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/tls/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/tls", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/home/bjkurlex/lib/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/x86_64", 0x7ffdff1b36f0) = -1 ENOENT (No such file or directory)
mmap(NULL, 92973, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fca080d7000
close(3)                                = 0
mmap(NULL, 3949248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fca07b09000
mprotect(0x7fca07cc3000, 2097152, PROT_NONE) = 0
mmap(0x7fca07ec3000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1ba000) = 0x7fca07ec3000
mmap(0x7fca07ec9000, 17088, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fca07ec9000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fca080d6000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fca080d4000
arch_prctl(ARCH_SET_FS, 0x7fca080d4740) = 0
mprotect(0x7fca07ec3000, 16384, PROT_READ) = 0
mprotect(0x55aacb3f2000, 8192, PROT_READ) = 0
mprotect(0x7fca080f0000, 4096, PROT_READ) = 0
munmap(0x7fca080d7000, 92973)           = 0
getpid()                                = 33763
rt_sigaction(SIGCHLD, {0x55aacb1e9460, ~[RTMIN RT_1], SA_RESTORER, 0x7fca07b3fcb0}, NULL, 8) = 0
geteuid()                               = 1000
brk(0x55aaccef1000)                     = 0x55aaccef1000
getppid()                               = 33760
stat("/home/bjkurlex/slickedit", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("bin/vs", O_RDONLY)                = 3
fcntl(3, F_DUPFD, 10)                   = 10
close(3)                                = 0
fcntl(10, F_SETFD, FD_CLOEXEC)          = 0
rt_sigaction(SIGINT, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGINT, {0x55aacb1e9460, ~[RTMIN RT_1], SA_RESTORER, 0x7fca07b3fcb0}, NULL, 8) = 0
rt_sigaction(SIGQUIT, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL, ~[RTMIN RT_1], SA_RESTORER, 0x7fca07b3fcb0}, NULL, 8) = 0
rt_sigaction(SIGTERM, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGTERM, {SIG_DFL, ~[RTMIN RT_1], SA_RESTORER, 0x7fca07b3fcb0}, NULL, 8) = 0
read(10, "#!/usr/bin/env sh\n#-------------"..., 8192) = 1599
pipe([3, 4])                            = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fca080d4a10) = 33764
close(4)                                = 0
read(3, "vs\n", 128)                    = 3
read(3, "", 128)                        = 0
close(3)                                = 0
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=33764, si_status=0, si_utime=0, si_stime=0} ---
rt_sigreturn()                          = 0
wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 33764
pipe([3, 4])                            = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fca080d4a10) = 33765
close(4)                                = 0
read(3, "bin\n", 128)                   = 4
close(3)                                = 0
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=33765, si_status=0, si_utime=0, si_stime=0} ---
rt_sigreturn()                          = 0
wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 33765
pipe([3, 4])                            = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fca080d4a10) = 33766
close(4)                                = 0
read(3, "/home/bjkurlex/slickedit/bin\n", 128) = 29
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=33766, si_status=0, si_utime=0, si_stime=0} ---
rt_sigreturn()                          = 0
close(3)                                = 0
wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 33766
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fca080d4a10) = 33767
wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 1}], 0, NULL) = 33767
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=33767, si_status=1, si_utime=0, si_stime=0} ---
rt_sigreturn()                          = 33767
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fca080d4a10) = 33768
wait4(-1, [{WIFSIGNALED(s) && WTERMSIG(s) == SIGSEGV && WCOREDUMP(s)}], 0, NULL) = 33768
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_DUMPED, si_pid=33768, si_status=SIGSEGV, si_utime=24, si_stime=4} ---
rt_sigreturn()                          = 33768
write(2, "Segmentation fault (core dumped)"..., 33Segmentation fault (core dumped)
) = 33
read(10, "", 8192)                      = 0
exit_group(139)                         = ?
+++ exited with 139 +++
  • Hero Points: 121
« Reply #7 on: July 19, 2016, 06:05:08 pm »
I think the strace just caught the bash script - 'vs' is a script that sets up some variables before calling the vs_exe executable.  The "-f" option for strace makes it follow forked processes as well.
Do you have a core file there?  The message says one was dumped, but if you have apport enabled, it may have intercepted the crash, and made it's own report.
If you have the core file, you can get a stack dump of the crash for us by running "gdb ~/slickedit/bin/vs_exe CORE_FILE_PATH", and then type in "bt" and hit return.
If apport is enabled, it generates a report in a large file in /var/crash that  a StackTrace field when it can determine the stacktrace.
  • Hero Points: 432
« Reply #8 on: July 19, 2016, 06:14:46 pm »
That would be very helpful. At this point, we definitely need more debug info. Is there any possibility you ran out of disk space?
b
  • Hero Points: 26
« Reply #9 on: July 19, 2016, 07:15:22 pm »
Well, no, I don't think I ran out of disk space.
bjkurlex@bullwinkle ~ $ df
Filesystem      1K-blocks      Used  Available Use% Mounted on
udev             32919768         4   32919764   1% /dev
tmpfs             6586224      1980    6584244   1% /run
/dev/sda1       414643184  22982888  370574600   6% /
none                    4         0          4   0% /sys/fs/cgroup
none                 5120         0       5120   0% /run/lock
none             32931100         0   32931100   0% /run/shm
none               102400         0     102400   0% /run/user
/dev/md0       4227181496 483148668 3529281340  13% /raid
 ;D
I'll reinstall again and see if I can generate a core to get to you.   Since I've had to use SE, I usually blow away the installation and restore my original 20.0.3 from backup.   I'll post more if I can get a core file.
b
  • Hero Points: 26
« Reply #10 on: July 19, 2016, 07:39:19 pm »
Well, attached is the strace with the -f option.   I'm still trying to figure out apport and how to get it to actually give me the report (or if I just need to get a good old fashion core).
b
  • Hero Points: 26
« Reply #11 on: July 19, 2016, 07:54:07 pm »
Okay, finally got a core file.
Reading symbols from bin/vs_exe...(no debugging symbols found)...done.
[New LWP 46004]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/home/bjkurlex/slickedit/bin/vs_exe +new -sc /tmp/config'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x000000000069782e in vsLangSetProperty2(VS_LANGUAGE_OPTIONS*, slickedit::SEString const&, slickedit::SEString const&, bool*, int) ()
(gdb) bt
#1  0x00000000006981f9 in vsLangOptionsSetProperty ()
#2  0x00000000006982da in vsLangSetProperty(char const*, char const*, char const*, bool*, int) ()
#3  0x00000000006983de in scLangSetProperty(char const*, char const*, char const*, int) ()
#4  0x000000000058a062 in call_dllpc(int, int, namelist_t*) ()
#5  0x000000000058bfa2 in run_proc(int) ()
#6  0x0000000000670cef in mac_first_init() ()
#7  0x0000000000677e40 in se_init(VSINIT*) ()
#8  0x0000000000643660 in vsInit ()
#9  0x00000000004e77ec in vmain(int, char**) ()
#10 0x00000000014da8a9 in xmain ()
#11 0x000000000049a1a9 in main ()
I'll squirrel away the core (32MB) if you want it.
  • Hero Points: 432
« Reply #12 on: July 19, 2016, 08:07:09 pm »
We will investigate this further to figure out the next step.
  • Hero Points: 432
« Reply #13 on: July 19, 2016, 11:33:07 pm »
So far all I can tell is that a language specific property is being set (don't know the name of the property or the line it's crashing on). It seems to be crashing in some pretty simple code (not the complex engine it makes calls into).
I have built a debug executable.
Please download http://support.slickedit.com/Outbound/v21-beta1/vs_exe.v21-debug
rename your bin/vs_exe to bin/vs_exe.old
copy vs_exe.v21-debug to bin/vs_exe
rm -rf /tmp/config
run bin/vs +new -sc /tmp/config
Upload the resulting core file
Choose the core to upload.
Thanks for your help!
b
  • Hero Points: 26
« Reply #14 on: July 25, 2016, 05:23:24 pm »
Uploaded core.gz
