Author Topic: minifind and Ctrl+F3  (Read 910 times)
  • Hero Points: 166
« on: July 18, 2016, 07:43:00 pm »
Open minifind.
Search for THIS
Click in the edit window.
Place the cursor on THAT.
Ctrl+F3
   Highlights THAT
Ctrl+F3 again
   Finds the next occurrence of THAT
F3
   BUG1: Finds the next occurrence of THIS
The Ctrl+F3 arguably should replace the minifind text with THAT
BUG2: Also, before pressing F3, Shift+Ctrl+F3 isn't consistent with Ctrl+F3
Ctrl+Shift+F3
BUG3: When WrapSearch is enabled in Minifind, F3 will wrap around to the top at the bottom, but Shift+F3 doesn't wrap back to the bottom from the top.
  • Hero Points: 123
Re: minifind and Ctrl+F3
« Reply #1 on: July 19, 2016, 03:14:15 pm »
Rather than modifying any options in any open find form (mini or Tool), I think the easier thing to do is to just dismiss the Mini Find any time another search command is executed.
Bug 3 confirmed, that will be fixed in next beta release.
