Author Topic: Tools > Options > Appearance > Colors: Updates  (Read 1729 times)
  • Hero Points: 185
« on: July 19, 2016, 10:02:33 pm »
Open a source file with some strings.
Normally the strings are RGB(0,80,80).
Place focus on "Profile".
Use the up and down arrows to cycle thru the schemes.
Go up to "Chalkboard".
The strings are green on nearly black.
Down to Cripsy, now they are pink on white.
Down to Default, the strings stay pink.
Wintergreen to Default or Crispy has the same issue, but more drastic things like Chalkboard do not.
So, why do some colors update as you cycle thru these, but others do not?
Clicking "Apply" seems to fix it.
« Last Edit: July 20, 2016, 12:37:56 am by Clark »
  • Hero Points: 429
Re: Tools > Options > Appearance > Colors: Updates
« Reply #1 on: July 20, 2016, 12:42:19 am »
Bizarre! The sample code edit window seems to always update but the Document edit window doesn't always update.
We will look into this.
  • Hero Points: 429
« Reply #2 on: July 20, 2016, 01:25:32 am »
This will be fixed in the next beta.
