Author Topic: Tools > Options > Appearance > Colors: Missing icons  (Read 1257 times)
  • Hero Points: 183
« on: July 19, 2016, 10:05:37 pm »
In the "Profile" dropdown, the built in color schemes used to have a Slick edit icon, while user defined schemes do not.
In V21, those icons are gone entirely.
Same for "Associated symbol coloring profile".
  • Hero Points: 183
Re: Tools > Options > Appearance > Colors: Missing icons
« Reply #1 on: July 19, 2016, 10:08:40 pm »
Also, it lets you delete the build in schemes, though they don't stay deleted.
  • Hero Points: 183
« Reply #2 on: July 19, 2016, 10:10:47 pm »
And rename doesn't work.
  • Hero Points: 418
« Reply #3 on: July 20, 2016, 01:43:45 am »
Good catch on the icons! Easy to fix.
The button issues for Delete and Rename was due to a single simple typo which incorrectly set the enable state.
