Author Topic: SE 21 often adds a space to the end of a line  (Read 3048 times)
  • Hero Points: 132
« on: July 29, 2016, 08:17:02 PM »
Hi:
In version 20, I highlighted an issue in a post here:
https://community.slickedit.com/index.php/topic,12119.0.html
It was said that this issue of extra space would be fixed in Version 21, however I am still seeing this issue.
  • Hero Points: 151
Re: SE 21 often adds a space to the end of a line
« Reply #1 on: August 01, 2016, 03:16:25 PM »
There's a fix in for the next beta for this.  My original idea of the problem's cause was wrong, so it ended up being an easier fix than I expected.
The one user-visible effect of this change is that beautifying on autocomplete is now grouped under the "Beautify while typing" setting, rather than the "Beautify alias expansions".  Which seems to make more sense.
  • Hero Points: 132
« Reply #2 on: August 01, 2016, 04:26:29 PM »
Thanks. By next beta you mean beta3? Or is it in the current beta2?
  • Hero Points: 151
« Reply #3 on: August 01, 2016, 07:21:38 PM »
Beta 3.
