Author Topic: Beta2 Redo bug  (Read 1401 times)
  • Hero Points: 190
Beta2 Redo bug
« on: July 30, 2016, 10:44:28 pm »
Beta2
Load "C:\Program Files\SlickEdit Pro 21.0.0 Beta2\macros\tbfind.e"
UndoAffectsCursorMovement:off
Undo bug
abc
<down><down><down>
def
<up><up><up>
<undo><undo><undo>
<down><down><down>
<redo><redo><redo><redo><redo><redo>
The REDO deletes the DEF.
You should be left with the below, except Redo deletes "def".
abc////////////////////////////////////////////////////////////////////////////////////
// $Revision: 60101 $
// defCopyright 2010 SlickEdit Inc.
  • Hero Points: 453
Re: Beta2 Redo bug
« Reply #1 on: July 31, 2016, 01:44:43 am »
Reproduced in beta2. Redo count is wrong.
  • Hero Points: 453
Re: Beta2 Redo bug
« Reply #2 on: July 31, 2016, 02:16:42 pm »
Fixed for beta 3
  • Hero Points: 190
Re: Beta2 Redo bug
« Reply #3 on: August 03, 2016, 08:00:50 pm »
undo/redo seems to be pretty unreliable now - but I've not been reporting other specific issues.
Often I can't undo things that I should be able to.
Do do think that Beta3 is likely to resolve this?
  • Hero Points: 453
Re: Beta2 Redo bug
« Reply #4 on: August 03, 2016, 09:05:06 pm »
Yes. The count issue is a bad bug. Sorry.
"If you don't want any bugs, don't write any code"  ;D
