Author Topic: How to close the pop-up about symbol color  (Read 2568 times)
wt11yn
« on: August 01, 2016, 07:09:05 am »
I've enable symbol color, But I want't see the pop-up information about "Symbol Color: ...".
How can I achieve this? Thanks!
  • Hero Points: 135
Re: How to close the pop-up about symbol color
« Reply #1 on: August 01, 2016, 01:08:48 pm »
I'm not sure what you mean, you want to see information for the symbol at the cursor?
Tim Kemp
  • Hero Points: 90
« Reply #2 on: August 01, 2016, 04:10:11 pm »
If you want to see the pop-up with the Symbol Color, just hover your mouse pointer over the symbol. To make it go away without moving the mouse, you can use a cursor movement key.
« Last Edit: August 01, 2016, 04:13:47 pm by Tim Kemp »
wt11yn
« Reply #3 on: August 02, 2016, 12:33:41 am »
I don't need the information in the pop-up. When I'm programing, I don't want to see what rule has been used to show the symbol color for me.
Do you mean I should press the keyboard to achieve this every time my mouse pointer hover over one symbol? Is there any other switch to achieve this in Tools->Options?
Tim Kemp
  • Hero Points: 90
« Reply #4 on: August 02, 2016, 12:40:55 am »
Sorry, I misunderstood. Unselect Options->Languages->Application Languages->C/C++->Context Tagging->Show info for symbol under mouse to change it for C/C++. Rinse and repeat for any other languages where you don't want it.
wt11yn
« Reply #5 on: August 02, 2016, 01:03:43 am »
Thank you Tim.
The pop-up do disappear when I just put the mouse pointer on symbols. But if the cursor is also on the symbol, then the pop-up appear again. Do you have any method to close the pop-up completely?
Tim Kemp
  • Hero Points: 90
« Reply #6 on: August 02, 2016, 01:22:39 am »
Sorry, I've used up my meager stock of knowledge.
wt11yn
« Reply #7 on: August 02, 2016, 03:31:32 am »
Hi Tim, I'm appreciated for your help.
Maybe there is no such switch to turn off this kind of pop-up, or maybe it is hiding somewhere and waiting for us, hehe
  • Hero Points: 435
« Reply #8 on: August 02, 2016, 03:24:28 pm »
If you post a screen grab of the popup, we'll have a better idea of what popup you are talking about.  It sounds like "show info for symbol under mouse", but Tim correctly instructed you to turn that off, so it must be another option.  I'm going to guess what you are seeing is related to auto-complete.  Options>Languages>Application Languages>C/C++>Auto Complete>Enable auto-completion.
wt11yn
« Reply #9 on: August 03, 2016, 01:01:15 am »
Hi Dennis, the pop-up is shown below. Thank you for help!
  • Hero Points: 435
« Reply #10 on: August 03, 2016, 03:52:21 pm »
OK, that helps, reproduced and fixed.  The fix will be in the next version of the v21 beta, and also in the next version of the hotfix for 20.0.3.
