Author Topic: Workspace preprocessing and symbols  (Read 2576 times)
  • Hero Points: 190
« on: August 05, 2016, 09:27:07 pm »
If I have this #define in my code:
   #define THINGS(arg1, arg2, arg3, arg4)  \
         typedef struct arg1\
            union\
               uint8_t         buf[arg3];\
         } arg1
And this in my CPP file:
   THINGS(my_data_type2, void, 123, void);
Then, from Workspaceproperties, I add the preprocessor symbol:
   #define THINGS(arg1, arg2, arg3, arg4) typedef struct arg1{union{uint8_t buf[arg3];};}arg1
(I copied it out of the workspace_cpp.h file).
It doesn't work - Slick cannot find the symbl "my_data_type_2".
If I put this:
   typedef struct my_data_type3{union{uint8_t buf[arg3];};}my_data_type3;
   my_data_type3;
in the same source file, now Slick can find my_data_type3.
  • Hero Points: 453
Re: Workspace preprocessing and symbols
« Reply #1 on: August 06, 2016, 12:02:11 am »
I'll look into this.
This could be a caching problem.  If you close and restart the editor, does the #define work for you?
  • Hero Points: 190
« Reply #2 on: August 06, 2016, 12:05:59 am »
Nope.
  • Hero Points: 453
« Reply #3 on: August 06, 2016, 12:15:26 am »
So the define is in your workspace_cpp.h file, you have the workspace open, and when you create a test file with just "THINGS(my_data_type2, void, 123, void);" in it, nothing shows up in the Defs tool window?
  • Hero Points: 190
« Reply #4 on: August 06, 2016, 12:25:16 am »
thats right.
I just selected RebuildTagFile for the workspace tag file from the tags dialog.
After a few minutes, Slick crashed.
Where can I upload the minidump?
  • Hero Points: 190
« Reply #5 on: August 16, 2016, 10:10:14 pm »
Working with Beta3 now .... this is still a problem.
I have a workspace made of about 8 projects, all the projects a wildcard files.
In FileX.cpp (which is in PrjX)
"THINGS" is defined in the workspace C preprocessing as I showed before, but after retagging the workspace my_data_type2 still isn't recognized as a symbol.
I tried having PrjX tags be in the workspace and in a separate tag file -- no difference.
I created a new workspace and added only PrjX to it. (same PRJ file - I didn't create a new project, just a new workspace).
I put the same definition for THINGS into C preprocessing for the new workspace, and now it works!
But, it doesn't work in the workspace I'd like it to work in :-(
OK .... I started playing with it more.
I found that THINGS would only work for defining that symbol if I made the workspace "TagFilesDirectory" be the same as where the workspace file itself lives.
Using PROCMON I verified:
Tagging is done with TAGGINGDIR\workspace_cpp.h
But, C/C++ Preprocessing editor in Workspace properties uses
WORKSPACEDIR\workspace_cpp.h
  • Hero Points: 453
« Reply #6 on: August 17, 2016, 06:13:37 pm »
Good catch.  This will be fixed in the next beta.
Did you ever send that mini dump from August 6 into support?
  • Hero Points: 190
« Reply #7 on: August 17, 2016, 06:34:24 pm »
where to send it to?
  • Hero Points: 453
« Reply #8 on: August 17, 2016, 06:44:49 pm »
Send it into support as usual, they'll forward it to me.
  • Hero Points: 190
« Reply #9 on: August 17, 2016, 07:53:48 pm »
I've uploaded it.CAS-68786-XB38
