Author Topic: Marker navigation  (Read 789 times)
  • Hero Points: 183
Marker navigation
« on: August 10, 2016, 10:10:46 pm »
What is the little map just to the left of the vertical scroll bar called?
I can't find it in help. It should be here: Help -> User Interface -> The Slickedit Interface
But it isn't.
Anyways, I have two side-by-side buffers.
On the left the buffer has two bookmarks and they are visible as little horizontal markers to the left of the scrollbar.
Clicking on these will sometimes navigate to the bookmark in the buffer on the left, and sometimes they will try to move to the bookmark line, but in the buffer on the right.
I remember in V19 or V20 I think I reported this issue, but I guess it is still there.
To repro, setup two side-by-side buffers.
Create some bookmarks on the left buffer.
Now, select the right side buffer.
Move the mouse slowly from the right buffer to this jump area on the left buffer - being careful to not move the mouse into the edit area of the buffer on the left.
Click - it navigates the right (that is, wrong) buffer instead of the left buffer.
It doesn't even matter which buffer has focus, it only matters which buffer that the mouse was most recently over.
  • Hero Points: 135
Re: Marker navigation
« Reply #1 on: August 11, 2016, 01:06:14 am »
We will look into this.
