Author Topic: Auto select of selected text when going from mini-find to find  (Read 1929 times)
TKasparek
  • Hero Points: 29
When you have text selected and hit Ctrl-F you get that text in the minifind window automatically. The search text is also selected so you can automatically start typing and have it replaced. This isn't carried if you hit Ctrl-F a second time and go into the regular find.
Re: Auto select of selected text when going from mini-find to find
« Reply #1 on: August 12, 2016, 09:02:41 pm »
Reproduced.  Will get that fixed in next build.
