Author Topic: Search option Use not remembered to next find  (Read 1374 times)
TKasparek
  • Hero Points: 27
« on: August 12, 2016, 08:50:11 pm »
This one is really bad for me as I use regex searches for everything...  :(
Open regular Find and Replace dialog (2xCtrl-f). Do a search using Perl Regex.
(Remember you forgot a search term...) Immediately open regular Find and Replace dialog (2xCtrl-f) again, Use is unchecked...
Re: Search option Use not remembered to next find
« Reply #1 on: August 12, 2016, 09:02:05 pm »
Yes, a change was made in the latest beta that copies the existing settings in Mini-Find to the Tool Find and Replace when you use it that way.  We may need an option or preference there or maybe just remove the feature.
TKasparek
  • Hero Points: 27
« Reply #2 on: August 12, 2016, 09:13:51 pm »
Well, following the same steps as before the second time through I checked to see if regex was enabled in mini-find and it was. It's not sent through to regular find.
I also just found the option for default search options 'Regular expressions'. Mine was OFF but changing it to ON didn't seem to change anything in regular find.
TKasparek
  • Hero Points: 27
« Reply #3 on: August 12, 2016, 09:35:42 pm »
OK, not as bad as I assumed. I hit the little down arrow to select regex in mini-find and assumed it was on due to Perl having a select by it. But it has a dedicated ON/OFF button next to that. Works for me once that was selected.
I will always have it enabled, I'm good with it as is.
Default every time still doesn't seem to work though, not that I'll use that either.
