Author Topic: multifile diff focus issue  (Read 1217 times)
  • Hero Points: 184
« on: August 13, 2016, 07:59:30 pm »
This is on Windows 10, I've not tried it on Windows 7.Diff beta2 vs beta3 macros.
select builtins.e
Press enter
it shows 3 differences.
Pick one and press enter -- diff opens.
Press ESC to leave.
Expected: Multifile diff should be on top.
But, instead Slickedit main window is on top and you have to manually select multifile diff to get back to it.
This may be caused by a very brief apperance of a progress dialog, which pulls Slickedit to front.
Note that when I select Builtins.e and press Alt+D (Diff), I don't have the focus problem when closing the diff -- it goes back to multifile diff as expected.
« Last Edit: August 13, 2016, 08:03:19 pm by jporkkahtc »
  • Hero Points: 137
Re: multifile diff focus issue
« Reply #1 on: August 15, 2016, 02:02:21 pm »
I'm looking into this.  Thanks for the report.
  • Hero Points: 137
« Reply #2 on: August 15, 2016, 03:12:15 pm »
This is fixed for the next build.
