Author Topic: list_clipboards and options  (Read 1279 times)
  • Hero Points: 190
« on: August 15, 2016, 08:28:04 pm »
In Tools > Options > Editing > General, select Maximum clipboards so you can type a number.
Ctrl+Shift+V
The list Clipboards dialog appears briefly, then closes without letting you select a clipboard.
Seems like it ought to either stay open, or it shouldn't open at all.
Also, in that same field - select it and type "50x".
Now Ctrl+Shift+V: ListClipboards opens, and then an error dialog "Please enter an int value" opens on top.
