Author Topic: vsdiff.exe: OpenInEditor  (Read 1603 times)
  • Hero Points: 184
« on: August 22, 2016, 09:20:19 pm »
Run Vsdiff.exe +t to compare two folders.
Right click a file, OpenInEditor.
Nothing happens.
If there is a VS running as well, it ought to open that file.
Or, the windows Explorer default action could launch whatever the default editor is.
Or, something.
  • Hero Points: 137
Re: vsdiff.exe: OpenInEditor
« Reply #1 on: August 23, 2016, 12:18:17 am »
I will look into this.
  • Hero Points: 137
« Reply #2 on: September 07, 2016, 02:59:11 pm »
This is fixed for the next build.
  • Hero Points: 184
« Reply #3 on: October 03, 2016, 10:25:42 pm »
Hm... OpenInEditor works, but  "Edit File" in the context menu while in the side-by-side diff of a specific file doesn't work.
It just closes the diff and you go back to the multi-file list.
