Author Topic: Function to get current column/line?  (Read 3908 times)
Mr68360
  • Hero Points: 3
« on: April 04, 2007, 10:00:34 pm »
Sorry for the basic question.
I just want the current column and line the cursor is on.
Tried this:
_command foo()
   _str s1 = "column is " :+ _p_col;
   say(s1);
   _str s2 = "line is " :+ _p_row;
   say(s2);
but compiler reports _p_col is not initialized (I suspect the property _p_col belongs to an Editor Control whose instance the macro cannot see).
What are the position functions??
Chuck
  • Hero Points: 325
Re: Function to get current column/line?
« Reply #1 on: April 05, 2007, 12:38:22 am »
Tried this:
_command foo()
   say(s1);
   say(s2);
_command foo()
   if (_no_child_windows()) {
    say('no child windows');
    return;
   _str s1 = "column is " :+ _mdi.p_child.p_col;
   say(s1);
   _str s2 = "line is " :+ _mdi.p_child.p_line;
   say(s2);
If the editor control is not an mdi child then you need to get its window ID and use window_id.p_col
