Author Topic: Projects being duplicated  (Read 3098 times)
davew
  • Hero Points: 6
« on: August 25, 2016, 03:10:30 PM »
I'm using Win7/64-bit.
SlickEdit Pro 2016 (v21.0.0.4 64-bit)
Installation Directory: C:\Program Files\SlickEdit Pro 21.0.0 Beta3\
If I go to to Project > Organize All Workspaces, I see lots of duplicate entries. I have attached an example screenshot.
  • Hero Points: 539
Re: Projects being duplicated
« Reply #1 on: August 25, 2016, 03:55:21 PM »
I'm seeing duplicates too. We will look into this.
  • Hero Points: 539
« Reply #2 on: August 25, 2016, 04:19:04 PM »
Check that you are actually seeing duplicates. Is the "Project:" field different? Click on each of the duplicate workspaces and see if the "Project:" field is the same.
  • Hero Points: 539
« Reply #3 on: August 25, 2016, 06:43:52 PM »
Hmm..I seem to be getting duplicates but I haven't quite figured out how to reproduce it every time. I think I'm getting close though.
  • Hero Points: 539
« Reply #4 on: August 26, 2016, 12:50:53 PM »
Found multiple issues. Your example definitely would hit a couple of the issues I've found. When you run beta 4, you will need to delete the duplicates since they are in your configuration. Migrating from a v20 config will be fixed in beta 4. That seems to have a problem with duplicates as well.
davew
  • Hero Points: 6
« Reply #5 on: September 06, 2016, 01:02:28 PM »
Sounds like you have a handle on it. I did see some that had info in the project field, but sometimes I would see several duplicates with nothing in the project field.
