Author Topic: C/C++ Split strings on Enter doesn't work  (Read 1296 times)
jnairb
  • Hero Points: 11
« on: September 01, 2016, 10:00:08 pm »
I'm running beta 4/Windows 7 x64. Under the C/C++ Comments options, I have "Split strings on Enter" selected. With beta 4, this is not working. It just splits the line the same as a it would when the cursor isn't inside a string, rather than splitting the line and adding new end/begin double-quotes for the string.
  • Hero Points: 453
Re: C/C++ Split strings on Enter doesn't work
« Reply #1 on: September 02, 2016, 12:21:17 pm »
We will look into this. Thanks for noticing!
  • Hero Points: 453
« Reply #2 on: September 02, 2016, 01:08:40 pm »
Fixed for next build
