Author Topic: find and replace / Find  (Read 1107 times)
wbullaughey
« on: September 03, 2016, 03:53:18 pm »
When the Find tab of the Find and Replace dialog box is selected by default when the dialog box is opened <Workspace> shows up as the 1st drop down. Since this tab is meant to be for finding in the current buffers rather then files it seams like <Workspace> should not be an option. Previous versions only gave the choice of <Current buffer> or <All buffers>
  • Hero Points: 444
Re: find and replace / Find
« Reply #1 on: September 03, 2016, 09:11:31 pm »
The Find/Replace Tab of the Find and Replace tool window is supposed to be a superset of the mini-find dialog. Both these dialogs can search <Workspace> and <All Buffers>. It would very odd for the bigger dialog to have less features.
The Find Tab defaults to <Current Buffer> if I start it with a clean config, open a workspace, and run the "tool-gui-find" command (or configure gui-find to display it).
