Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2016 v21 Beta Discussion
tab color while doing replace
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: tab color while doing replace (Read 2812 times)
wbullaughey
Community Member
Hero Points: 2
on:
September 04, 2016, 10:34:58 AM »
When doing a multi buffer replace the current buffer's tab color does not get set.
Logged
SlickEdit Team Member
Senior Community Member
Hero Points: 539
Re: tab color while doing replace
Reply #1 on:
September 04, 2016, 01:21:29 PM »
With a multi-file replace, the buffer gets saved so it's no longer modified.
Logged
wbullaughey
Community Member
Hero Points: 2
Reply #2 on:
September 05, 2016, 06:32:38 PM »
I was looking for it to be set to the current buffer color while the "Prompt Replace" message box is displayed for conditional replace.
Logged
Hero Points: 539
Reply #3 on:
September 06, 2016, 01:54:02 AM »
During a prompted multi-file replace, the color of the tab changes for me until its done with the file because it gets saved and is no longer modified. If there's only one prompted occurrence, you'll never see the tab change color.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
