Author Topic: Invisible flyover problem  (Read 9915 times)
unMinou
« on: September 12, 2016, 02:21:04 pm »
I installed the beta version to see if I could justify the purchase of SlickeEdit for Linux. So far I cannot unless this is only an issue with the beta version. I do not have one to check this out.
We have several licenses for windows but I would have like to have one for Linux. My main reason for using Slick Edit is the support for the brief editor.
When going over the files in the Projects section I see a flyover that is light yellow with light white letters.
What's with that? I didn't see any way to change the colors for those, where do I go for that?
Michel
  • Hero Points: 144
Re: Invisible flyover problem
« Reply #1 on: September 12, 2016, 03:05:42 pm »
Which Linux?
Are you using the default color scheme in SlickEdit?  Are you using a special color scheme in your Linux?
unMinou
« Reply #2 on: September 12, 2016, 03:24:22 pm »
I have not changed the color schemes yet.
The Linux I use here at work is Ubuntu 14.04. I only use ubuntu because that is the only thing that Texas Instruments supports. Redhat makes a better linux ...
I use the Mate Desktop with TraditionalGreen Theme. I tried different Themes and it doesn't make any difference.
Michel
  • Hero Points: 144
« Reply #3 on: September 12, 2016, 03:39:30 pm »
We're still working on trying to reproduce this.  What we're seeing here with a typical Ubuntu installation is black letters on a yellow background.
unMinou
« Reply #4 on: September 12, 2016, 03:48:19 pm »
You need to test with a Mate Desktop. You are likely to have issues with mint as well.
Tonight I will check to see if the same issue exists on Scientific Linux. Perhaps you should try some other background than yellow or at least make it possible to change those colors.
Michel
  • Hero Points: 144
« Reply #5 on: September 12, 2016, 04:01:32 pm »
Can you please post a screenshot?
We just installed Mate Desktop, and so far we still cannot reproduce the problem (we are still trying though).
unMinou
« Reply #6 on: September 12, 2016, 04:19:44 pm »
Here is picture as an attachment. I had to use my camera since the flyover goes away when I do a print screen.
Michel
  • Hero Points: 484
« Reply #7 on: September 12, 2016, 05:50:53 pm »
Totally not readable. We will try to make this configurable soon.
  • Hero Points: 142
« Reply #8 on: October 26, 2016, 02:59:26 pm »
As an update, we found a workaround for the bad tooltip colors under linux with the MATE desktop:  https://community.slickedit.com/index.php/topic,14388.0.html
