Author Topic: RC2: Look in current procedure not working on my source file  (Read 1081 times)
  • Hero Points: 118
« on: September 22, 2016, 04:21:15 pm »
I have uploaded test5.c to support.slickedit.com.
Go to line 15 and search for "beta0" and look in "current procedure" with "list all occurrence" checked.
No occurrences of beta0 are found.
If you change look in to "current buffer", it does find all the occurrences.
Note that "select-proc" works on this function. Yet nothing is found when searching with look in "current procedure"
« Last Edit: September 22, 2016, 05:52:00 pm by rowbearto »
Re: RC2: Look in current procedure not working on my source file
« Reply #1 on: September 22, 2016, 06:04:23 pm »
We did discover an issue in RC2 release with search in Current Procedure.  Fixed for RC3.
