Author Topic: Goto line does not work any more  (Read 19060 times)
  • Hero Points: 485
Re: Goto line does not work any more
« Reply #15 on: June 08, 2017, 01:11:48 pm »
You could be right for sure. We'll see. There could also be a language barrier. I've seen that before.
Judy Li
« Reply #16 on: June 08, 2017, 01:51:17 pm »
It is a real posting, not a spam.
I checked the old postings, and could not figure out a solution for my case.
  • Hero Points: 485
« Reply #17 on: June 08, 2017, 01:57:01 pm »
With v12, you can check your key binding for Ctrl+G with the following steps:
Tools>Options>Key Bindings
Click "Add Key or Mouse Click.."
Press Ctrl+G
This will show you what command Ctrl+G is bound to.
  • Hero Points: 337
« Reply #18 on: June 10, 2017, 11:10:44 am »
ok, sorry for the spam accusation.
Did you get goto line working?  Did you know you can type a number xx on the slick command line and slick will go to that line?  Or you can type goto-line xx on the command line and slick will also go to line xx.  Also you can type list-keydefs on the slick command line and slick will list all your keybindings  - all 900 or so!
Did goto line ever work?  If so, when did it stop working?
