Author Topic: RC3 Can't bring up full find/replace dialog from mini dialogs  (Read 2529 times)
link
  • Hero Points: 3
« on: September 27, 2016, 01:57:36 pm »
I can no longer bring up the find or replace dialog by pressing the hot key a second time when the mini dialog is up.  Is this intentional?
Re: RC3 Can't bring up full find/replace dialog from mini dialogs
« Reply #1 on: September 27, 2016, 02:41:54 pm »
No, it is still supposed to allow this.  What is your emulation and key-bindings for find and replace?
link
  • Hero Points: 3
« Reply #2 on: September 27, 2016, 03:15:33 pm »
I use Emacs emulation, and here are the bindings I use:
ALT+F - gui_find
ALT+R - gui_replace
  • Hero Points: 484
« Reply #3 on: September 27, 2016, 06:12:05 pm »
Can you reproduce this with a default config and making minimal changes? (Emulation/bind keys)
We can't reproduce this.
link
  • Hero Points: 3
« Reply #4 on: September 27, 2016, 10:51:43 pm »
Apparently not--it works fine if I do that.  I exported all my old settings and re-imported them into a fresh config, and it still works as expected.  I can provide my old config dir if you feel this is worth tracking down, but otherwise it appears to be working fine so far.
  • Hero Points: 484
« Reply #5 on: September 27, 2016, 11:01:08 pm »
Glad it works. Probably not worth tracking this one.
