Author Topic: RC3: Bad indenting after pressing space after "if"  (Read 2062 times)
  • Hero Points: 119
« on: September 27, 2016, 03:17:18 pm »
I have uploaded a file (main.cpp) to support.slickedit.com under "RC3: Bad indenting after pressing space after "if""
Go to line 4579, which is just an "if". Place the cursor just after the "f". Now press <space>. You will see that the resulting indenting is all wrong.
Thanks!
Rob
  • Hero Points: 119
Re: RC3: Bad indenting after pressing space after "if"
« Reply #1 on: September 27, 2016, 05:14:15 pm »
Got it, we're taking a look at it.
  • Hero Points: 119
« Reply #2 on: September 27, 2016, 05:18:01 pm »
Thanks. Did you reproduce it?
  • Hero Points: 427
« Reply #3 on: September 27, 2016, 06:07:24 pm »
Yes
  • Hero Points: 119
« Reply #4 on: September 27, 2016, 07:01:34 pm »
The fix for this isn't going to make it into RC4, but it should be in for the build after that, or in the first hotfix.
  • Hero Points: 119
« Reply #5 on: September 28, 2016, 09:20:30 pm »
Actually, the fix for this is going to be in the RC4 build.   Thanks again for the report.
