Author Topic: VSDiff errors  (Read 2292 times)
  • Hero Points: 188
VSDiff errors
« on: October 03, 2016, 10:35:04 pm »
Related to the other post here about vsdiff throwing errors...
Compare two folders
    vsdiff -t a b
Click "options"
##Bug1:
Overlapping text in the options dialog
Change something
##Bug 2:
Click "Save Options"
SlickEdit Pro
This item must be a valid path or filename
OK
Sometimes, I get two more errors as well:
SlickEdit Pro
Failed to save configuration to 'C:\Users\joe\Documents\SlickEdit\21.0.0\vslick.sta'.
Access denied
OK
SlickEdit Pro
Unable to save the configuration
Do you want to correct the problem and try again?
If you can't correct the problem, your configuration changes will be lost.
&Yes   &No
And I now have an empty "Diffzilla Pro" window on top of MultiFileDiff.
  • Hero Points: 137
Re: VSDiff errors
« Reply #1 on: October 04, 2016, 01:03:45 am »
I fixed the control collision.
I can't reproduce the Save Options problem.  I tried typing in various paths (valid and invalid).  Can you still reproduce this?
  • Hero Points: 444
Re: VSDiff errors
« Reply #2 on: October 04, 2016, 01:23:32 am »
Did bug#2 happen on exit?
If so, that's been fixed.
  • Hero Points: 188
Re: VSDiff errors
« Reply #3 on: October 04, 2016, 01:28:40 am »
For this repro I've got VS running, then from a CMD window I run vsdiff.
#2 happens when you click SaveOptions.
  • Hero Points: 444
Re: VSDiff errors
« Reply #4 on: October 04, 2016, 01:49:41 am »
I missed the first message box for bug#2. I was really asking if the second two message boxes which only happen sometimes for you happen when you exit. That's been fixed.
We can reproduce the first message box for bug#2
  • Hero Points: 444
Re: VSDiff errors
« Reply #5 on: October 04, 2016, 02:44:09 am »
All fixed for next build
