Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2016 v21 Beta Discussion
RC4: defs window is confused by print function
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: RC4: defs window is confused by print function (Read 5452 times)
Senior Community Member
Hero Points: 206
Text
on:
October 06, 2016, 11:37:14 pm »
I have a class with a print() function.
The defs window doesn't much like this - instead of the function, it shows variables defined inside the function.
If I change the name of the function, then defs is correct.
Logged
SlickEdit Team Member
Hero Points: 485
Re: RC4: defs window is confused by print function
Reply #1 on:
October 07, 2016, 01:12:14 pm »
print was a keyword in Python 2.x but it isn't any more. SlickEdit has one parser for handling both versions of Python. In this particular case, removing print as a keyword will fix this for the parser. This will be fixed in a future build. v21 has just gone gold.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
