Author Topic: Regex replace syntax for replace with wildcard  (Read 6003 times)
JimmieC
  • Hero Points: 16
« on: October 12, 2016, 02:31:50 pm »
How can I replace the following text? Basically, I want to move .. 00 00 21(to end of line) to the start of a new line.
10/11/2016 18:04:37.370 [RX] - FD 00 00 21 1E 00 FD 00 23 20
10/11/2016 18:04:37.370 [RX] - 30 00 00 21 1E 00 FD 00 23 20
10/11/2016 18:04:37.370 [RX] - 80 00 00 21 1E 00 FD 00 23 20
Using recorded a macro:
Ctrl-F11
search for " .. 00 00 21" (leading space)
Go in front of .. with cursor
Hit return
Ctrl-F11
Then hold down Ctrl-F12 until the string is no longer found (thanks for stopping macros on fail case now!)
However, some of these files are very long so Replace will be faster. I would like to do something with replace like:
Find " .. 00 00 21" (leading space)
Replace "\R.. 00 00 21" -- But, of course, the dot-dot will not work here.
  • Hero Points: 467
Re: Regex replace syntax for replace with wildcard
« Reply #1 on: October 13, 2016, 12:51:08 am »
That should work. Make sure you turn on regular expressions
