Author Topic: 64-bit, options import/export, XML, Java, Subversion, misc  (Read 1651 times)
PlanetPratt
  • Hero Points: 6
« on: July 03, 2009, 07:46:31 pm »
  • 64bit Windows support
  • More Complete export/import support (currently doesn't save menu's, toolbar, and more...)
  • Better XML Support (Specifically better support for DTD/Schema/RelaxNG/XSI...)
  • Use Regular Expressions instead of Extensions to detect the document mode
  • Multiple embedded language support
  • Improve the Java Live Errors with lots more error/warning options
  • Bring back and expand the Java Refactoring support
  • Eclipse like error/warning strip on the right of the editor (Especially in Eclipse Plug-in)
  • Subversion Integration (Maybe there's a way to leverage TortoiseSVN (and CVS and Git) directly so you don't have to do it yourself
That's all I can think of now, but I reserve the right to come add things to my list  ;)
  (*Chris*)
