Author Topic: Rich text display, Mercurial support, improve split window support  (Read 711 times)
byates
  • Hero Points: 8
  • Change the code display window so that it supports simultaneous fixed space and variable spaced fonts and multiple font sizes: rich text display.
  • Add an option to decode and display in-line any comments which contain doxygen tags, embedded HTML tags, etc.
  • Add in-line display of embedded COM objects (ex: doc or visio) or images (use comments to contain the reference or data)
  • Add mercurial support  ;D
  • Add hook for writing user extensions in .NET primarily for doing complicated dialogs and user windows
  • Improve split window support.  It is too easy to 'break' the connection between windows and the divider takes up too much room.
