Author Topic: Handling compiler error-parsing  (Read 5561 times)
HansNet
« on: April 16, 2007, 08:09:13 pm »
At the company I'm working we want to start using SE for editting (on pc) and compiling (on the host mainframe system). For downloading and uploading files from/to the host a Slick-C macro is used that calls a function in a dll which makes a winsock connection.
For the compilation-process also a function in the dll is called via a Slick-C macro. This dll-function does the following :
- upload the modified source-file from the pc to the host
- send a command to the host that triggers a compilation at the host
- waits for the compile to end
- when the compile went wrong the dll receives the name of the hostfile, that includes the compiler-errors
- the (host)error-file is downloaded to the pc
- then the dll-call, from out of the Slick-C macro, returns and the Slick-C macro continues. The Slick-C macro knows the fysical location of the download error-file on the pc (lets say C:\hosterrors.txt)
This file contains one line per error (pc-filename, line, column, error-tekst).
I already have setup an error-parser via "Build - Configure error parsing" in the category "user". I named it "myerrorparser". I validated it on a line in C:\hosterrors.txt and it works.
But now my question : how do I get the compile-error window (or whatever it is called) activated and filled with the errors in C:\hosterrors.txt via parser "myerrorparser"  .... so that I can double-click on an error to correct the error in the sourcefile.
Can somebody please tell me how to do this in a Slick-C macro ?
  • Hero Points: 288
Re: Handling compiler error-parsing
« Reply #1 on: April 16, 2007, 10:51:55 pm »
Hi HansNet,
you could try this sample. It's just a remix of a few related things already posted.
Hope it works for you !
_command void hpostbuild ( )
   // reset a few things
   reset_next_error();
   clear_all_error_markers();
   clear_pbuffer ();
   cmdline = "C:\\hosterrors.cmd";
   concur_command (cmdline);
this little helper:
_command void serr () name_info(','VSARG2_REQUIRES_EDITORCTL)
   set_error_markers();
   refresh('A');
   // maybe goto 1st error
   if ( next_error () )
      // or not ...
      bottom_of_build ( );
      cursor_data();
      _beep ();
and hosterrors.cmd
type C:\hosterrors.txt
echo <binary 1>serr
I attached the batch incl. the <binary 1>.  The forum SW hangs when a <binary 1> is contained in the message text.
(It also contains the Slick macros.)
HansNet
« Reply #2 on: April 17, 2007, 08:35:25 pm »
thanks ... I got it working. One additional question ... when the cmd-file is executed, it types the text-file with the errors in it, I get the following information visible in the build window :
F:\>F:\hosterrors.cmd
*F:\SSCFORW0.sco(29)Error C2078: too many initializers
*F:\SSCFORW0.sco(31)Error C2078: copy not found
F:\>
line 2 and 3 are my errors in the typed txt-file, but line 1 and 4 also appear. When I double-click on line 1, hosterrors.cmd is editted. When I double-click on line 4, a "Find file" window appears to select a file.
How can I get rid of line 1 and 4 ?
And do you perhaps know how to deal with spaces in some of the directories in the path ?
Like example when I do "type C;\my docs\err.txt" in a dos-box ... it gives an error because of the one space after "my".
  • Hero Points: 288
« Reply #3 on: April 17, 2007, 10:54:31 pm »
@HansNet: Glad to hear that it's working for you !
Golden rule: Avoid SPACEs in filenames/paths. It makes life a lot easier ...
Otherwise you need to quote them like this: type "C:\Path with SPACEs\file with SPACES.txt"
The line 1 and 4 cannot be removed. Remember that the 'Build' window is just wraps and enhances the cmd shell but incl. prompt etc.
So you shouldn't d-click (same as r-click->Goto Error) on the lines you are not interested in or just ESCape the 'Find File' dialog after accidentally doing so ;)
