Author Topic: Select Files dialog, RW dialog, project wildcards, 64-bit linux  (Read 1098 times)
StuartGMentzer
« on: December 04, 2009, 07:32:24 am »
1. Way to disable the annoying new "Select Files to Open" dialog
2. Way to disable the annoying dialog when you hit RW and just want the file read-only from the editor's perspective (not the file system)
3. Automatic project file list mode: e.g., everything under path with a name filter of *.py. Manually maintaining projects is error prone and a pain.
4. Stop adding "features" that aren't usability tested and can't be turned off!
5. Make the Linux version more stable, less ugly, and with a native 64-bit version
Tree
Re: Select Files dialog, RW dialog, project wildcards, 64-bit linux
« Reply #1 on: December 04, 2009, 04:58:47 pm »
I do all my projects this way. How else can you do them?
project properties (or creation) -> add wildcard "*.py", check the recurse button.
Or is there something different you mean?
