Please make file tabs sticky. Currently when there are many files open and too many tabs to fit the tool bar, two scroll buttons appear. If I scroll way over to the right, as an example, and click the right-most tab, I get the proper file. However, if I next click a tab that is 6 tabs to the left of the right-most, the entire set of tabs automatically scroll to the right. The new file is displayed properly. The problem is if I now want to go back to the right-most tab, I have to use the scroll buttons. Please provide a feature where the tabs do not automatically scroll when they are selected.
If I recall, the sticky feature was built into previous versions SlickEdit.
